Perform this procedure to specify the RSTP mode.
    enable
    configure terminal
  2. Configure Rapid Spanning Tree Protocol version:
    spanning-tree rstp version {rstp|stp-compatible}
Switch:1(config)# spanning-tree rstp version rstp
Use the data in the following table to use the spanning-tree rstp version command.
Variable
Value
Sets the version to RSTP or to STP compatible.
The default is RSTP.
